Reply To: Lighting for renders
October 16, 2024 at 3:49 pm #439723
Cheryl Parks
Hi Dan,
Do you have the Underground catalog? I use Underground >> Decorative Items >> Lighting >> Invisible (for lighting effects) >> INV-LT880.  Then when it’s on the floor plan right click and go to Light Properties.  Change intensity to 120 watts.  You can use as many as you need as they don’t show up in the perspectives and you can hide them on the floor plan.
Another thing that I do if I have open areas without walls is to draw walls around the entire design.  It keeps the light in.
I hope this helps.
Cheryl
