October 31, 2015 at 9:45 am
#56582
Inactive
Jon,
After viewing your link, the mouldings should be continuous without butting into each other. That alone can cause the crash. The designer needs to run the mouldings to the outside of the cabinet face frame and then stack you next piece of moulding using a continuous line, no butt joints. It’s sometimes better to use the elevation mode to set your stacked mouldings and adjust the heights of each piece to your desired heights. Butt joints with your mouldings can cause countless issues, always use continuous mouldings.
