October 31, 2015 at 11:50 am
#56589
Inactive
Jordyn, I also checked the specs on your graphics card, the recommended power supply is min. 400 watts, that’s minimum. Hope that some of this helps. You also stated that you removed and reinstalled 2020 several times, did you clean out the registry after removing 2020, before reloading? You should always remove 2020, restart the machine, clean out the registry with CCLEANER, shut down-restart the machine and then reload. This will give you a clean install—
