November 16, 2015 at 9:23 pm
#58428
You alter this by adjusting the ‘display scheme’
Right click on a blank area of the design. Choose Display Settings and a window will pop up.
Make a note of the Scheme name near the bottom of the Window.
You will see various tabs across the top – choose dimensions.
Click on the plus symbol by Auto Dimensions and pick Residential.
You can expand anything with a plus sign and then tick or untick boxes until you get th dimensions the way you want them. When you are happy, choose Save As and then save the Scheme name using the name you noted before.
You can adjust the measurements, what’s included, etc etc.
Same method for elevations.
