Reply To: WishList
January 23, 2016 at 11:18 pm #70928
Rindi Daniel
Using newest 11.3. I feel comfortable with the new rendering tool, but I am not a fan of the the placement of the new camera.  I like the camera placement option so much better in earlier versions where you could just set the camera and its view by  scrolling through right clicking the mouse.
-More corbels and just general room catalogs in all decor updated—especially appliances..:) Nice to have a front load with a modifiable pedastal
-better generic appliances
-saving textures that you can use on all designs and truly be a user-defined texture to be used on other designs without having to re-use the wizard
-add barnwood flooring options-not enough color selections
-modifiable or larger selection of room tiles-alot of clients are going with a variable size floor tile or rectangular tiles and not your average 4×4/12×12 etc tile.  Nice to have  catalog of more current backsplash textures
-when writing notes, be able to adjust display settings / font size/ etc all at the same time in the window
-application and selections of room crown
-larger selection of window trim and sizes (My clients typically use RB3 case molding which is 3.473″ wide and they sometimes use trim up to 5 1/2″.  It would be nice if the width of the molding would visually modify and not just allow you to change the width in the variable and it not actual change the visual. Doors as well
-easier application of base molding to room as well as a shoe molding or quarter round.  perhaps an auto design of these areas like when you set c-tops and toekicks and trim, but he capability to stack them as well. Then be able to delete or modify areas that you want to just like you do other trims. Even if it would place room crown and you could manually lower it would be fine.
-Thank you so much for your attention.  It truly means alot that our thoughts do not go unnoticed.
