Reply To: Countertop Wizard Issues
June 3, 2016 at 10:25 am #91041
Hi Bobbi,
The only way to edit countertops placed using the Wizard is to delete them and run through the Wizard again.  You can customise your tops by selecting “Choose a specific shape…” instead of Autodesign.  You might need to run through the Wizard a couple of times to get all your countertops in but you can build each piece one at a time if you want.
To select a cabinet that is under the countertop just right click over the cabinet and select the cabinet from the list that comes up.
Hope that helps
