Reply To: Countertop Wizard Issues
July 6, 2016 at 2:33 pm #94417
Chris Setlock
Hi Bobbi,
Two ways I can think of to get the countertop you want.
First way is to determine in advance the size you want, and select the appropriate shape from the list, then manually enter the size instead of allowing it to design over exiting cabinets.  You’ll get the countertop in the size you want, then you just need to drag it into position.
Second way is to allow countertop wizard to design it incorrectly, then edit the shape.  You can edit tops made by countertop wizard, though it’s a bit clunky.  Hover over the element you wish to edit (line or corner) then right click.  The countertop will be listed in the pop-up menu, and within that, the element (line or corner) is in a sub-menu.  From there you can move a line to change the size, pull a corner point to a new position, radius or clip a corner, etc.
The trick is learning which method is quicker, or more accurate.
Ilona, to use a different sink than the ones in the wizard, find the sink you want, and place it in the cabinet first.  Then go through the wizard.  When you get to the sink dialog, the sink you placed will be there.  If it’s written in red letters, it has a detail that needs to be edited (usually the wizard wants to know if its cast iron or not).  Just click on the sink, then click the edit button at the bottom of the box.
