Reply To: Texture Material Appearance Broken 11.5
July 7, 2016 at 10:09 am #94513
Hi Guys,
The super dark user defined textures is an issue in v11.5.1. They are aware of it and working to resolve it but I do not have any kind of timetable as to when it will be resolved.
You can roll back to version 11.4 by doing a basic uninstall of the program from the programs and features option of the Windows Control Panel. Go to the control panel, if you only have 8 choices go to the drop down menu in the upper right and select small icons instead of catagories. Then select programs and features and you should be presented with a list of all the software installed on your computer. Let the list populate and the select Design. With design selected click on change. This will start an “installer”. Next, remove, basic uninstall, next, remove, finish and Windows will uninstall version 11.5(It can take a couple of minutes to get from Remove to Finish). Once you click finish you just reinstall version 11.4. Using the basic uninstall allows you to keep your catalogs so you don’t need to reinstall them.
