July 12, 2016 at 10:31 pm
#95108
Unfortunately, if it’s gone then a registry reset is the only option. You shouldn’t lose dimension settings as these are controlled by the display schemas which aren’t touched by a registry reset.
You will lose all your preferences so before you do the registry reset, why not go through each preference screen, capture them using the Snipping Tool and print them out?
