Reply To: Where do you go to change the text in the title block on your printed drawings
July 18, 2016 at 9:03 pm #95843
Hi Christina,
The Drawing Layout feature is customisable but a bit of a pain to use. I found it much easier to set up whatever layout you want in a Word document and then to store plans, elevations and renders as pictures and then just paste them into the Word template you created,
Another way (as Neil has mentioned) is to use a PDF ‘printer’ that allows you to use overlays that you have created elsewhere.
