June 9, 2020 at 6:16 pm
#285687
Hi Mark,
Yes, you can use your MacBook Pro as long as you install BOOTCAMP. To set up bootcamp, you should call Apple Support and get some assistance from them.
Be sure however that your machine is up to the task.. Make sure it has the system requirements that we need. You can find the requirements HERE.
However, we do not support the program if you are running on parallels. You must use the program on the machine itself.
