March 25, 2019 at 10:15 am #230900
Kullen Biller
ParticipantHello, I was curious to know if there was a way to create a custom opening or passthrough in a wall? In a design I’m working on I have a vaulted ceiling in one room but then steps down into another room that also has a vaulted ceiling but the two vaults are different heights. I used the “Cathedral Top Wall w/Ceiling Exp.” for one rooms vault and I could change the wall heights in the second room to make the vault but I would need to create a custom opening between the two rooms to connect the two. I’m open to any other options too if anyone has any suggestions. Thank you
March 25, 2019 at 10:43 am #230912
Neil WilsonParticipantHey Kullen,
I’m not sure exactly what you would need but you can build pretty complex passthroughs by combining the shapes from our openings and obstacles\wall-cutouts and playing with their attributes.
November 24, 2019 at 10:36 am #260426
Ron Russell
ParticipantWould a construction line work between the rooms, instead of a wall?
March 25, 2019 at 2:57 pm #230946
Kullen Biller
ParticipantI’ve messed around with the openings and obstacles/wall cutouts and was not able to make what I’m looking for. Is it just me or is there no Triangle cutout/passthrough? I haven’t seen one anywhere, that’s really what I need. Basically I need to make a rectangular opening with a triangle on top of it to match the vault.
March 27, 2019 at 5:16 pm #231240
The only thing I could come up with for a triangular opening was to use a triangular window on top of the rectangular passthrough. It looks pretty good in hidden line but not so much in texture.
There are unfortunately no triangular pass-throughs in 2020. I’ll point that out to our product manager. 🙂
March 27, 2019 at 6:43 pm #231241
Ariana ThompsonParticipantYou could also put in a standard door opening with no frame – then fill in the two upper corners of the doorway with custom shape triangles…..
March 27, 2019 at 6:53 pm #231242
Ariana ThompsonParticipantLike this….. in one I coloured the triangles so they stand out.
In the other image they are coloured to match the wall….
March 27, 2019 at 7:12 pm #231243
Ariana ThompsonParticipant<p style=”box-sizing: border-box; margin: 0px 0px 1.313em; color: #7e8083; font-family: Lato, sans-serif; font-size: 14.85px;”>Like this….. in one I coloured the triangles so they stand out.</p>
<p style=”box-sizing: border-box; margin: 0px 0px 1.313em; color: #7e8083; font-family: Lato, sans-serif; font-size: 14.85px;”>In the other image they are coloured to match the wall….</p>Attachments:
March 28, 2019 at 9:48 am #231340
Neil WilsonParticipantThat’s Brilliant! Thanks Ariana.
March 28, 2019 at 10:33 am #231344
Ariana ThompsonParticipantNo problem, Neil 😉
Don’t know why that was a weird double post from me…… oh computers!
March 28, 2019 at 10:35 am #231345
Kullen Biller
ParticipantThank you all for the help and suggestions. I found another way around it for what I needed. this homeowner wanted to add beams to his vaulted ceiling so once I figured out the dimensions and needed for those I just made a beam the width of a wall and then made it really tall and matched the color to the wall to fill in the space between the two different vault planes.
March 28, 2019 at 10:59 am #231356
Ariana ThompsonParticipantBeautiful!
November 25, 2019 at 9:50 am #260494
Neil WilsonParticipant@Ron
I don’t know why your post got moved to the middle of the train Ron but depending on what you are trying to accomplish a construction line could work. A construction line is basically a transparent wall.
