I have multiple designers using the same PC’s and need to duplicate the standard company preferences across multiple user profiles on each PC. Ages ago I exported the registry from the master 2020 setup and imported it for each user. That stopped working in the 2020 Versions > 9. Does anyone know how this could be accomplished with the current version?
Basically , if a designer needs to use PC other then the one she usually uses, I need her to login with her Windows login and start working immediately without having to modify preferences to out standard.
