September 27, 2015 at 7:57 pm #513272020Participant
Anna
Please see the direct link to our webpage
if you scroll down to your right you will a section “2020 Design try it free”
September 29, 2015 at 10:52 am #51583Neil WilsonParticipant
Hi Anne,
Version 11 is compatible with Windows 10
October 26, 2015 at 8:31 pm #55930Mike LangensiepenPilot Pro
There is no OSX version available. You can try and run 2020 under Parallels or Fusion but there are issues doing this. The only reliable solution is to use Bootcamp to run Windows natively on the Mac.
February 12, 2018 at 4:07 am #169876j Antonio AyoraParticipant
I downloaded 2020 fusion version trial i installed and i tried to access but the ask me for a activation code, where i can get that? I did not received anyone in my email
Many thanks
February 12, 2018 at 11:08 pm #170040Mike LangensiepenPilot Pro
This is the 2020 Design forum – the 2020 Fusion forum is here:
Or are you trying to run 2020 Design on a Mac? If yes then you need VMWare Fusion (same program name, completely different thing!):
https://www.vmware.com/au/products/fusion.html
You will have trouble if using a Mac tho – the only reliable method of running Windows programs on a Mac is to use Bootcamp which boots Windows instead of OSX.
